Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: jumpng solenoid fails to crank ( 1020 gas)
[Return to Forum]
Chris Tractor
06-20-2012 10:20:31
216.158.161.19
I jumped to the S post on the solenoid. Key in ON position, got lots of spark she will not crank still just a click same as turning the key. Noted that the wires from "I" terminal to coil were quite warm when I finished. What is the next thing I should do?
[Reply]   [No Email]
husker44a
06-20-2012 12:11:04
8.28.70.17
 Re: jumpng solenoid fails to crank ( 1020 gas) in reply to Chris Tractor, 06-20-2012 10:20:31
Chris. When you jump directly from your pickup battery to the starter you are bypassing the solinoid. Direct power your the starter. Like I said before. It should start so be VERY CAREFUL. When it does. Replace the starter solinoid.
[Reply]  [No Email]
husker44a
06-20-2012 10:39:31
63.172.255.242
You can jump it going directly to the starter. BUT I AM WARNING YOU. Make SURE it is in Nuetral and Brakes are SET. Hook cables up to your pickup. Then clamp the GROUND on the frame of the tractor as to get a good ground. Then, this is where you HAVE TO BE VERY CAREFULL. Key ON. With the POSITIVE cable touch the positive post coming from the starter solinoid to the STARTER. It will start. Because you are by-passing the starter solinoid. BE CAREFULL !!!!!!!!!. IF IT starts doing this. The starter solinoid is BAD.
[Reply]  [No Email]
Chris Tractor
06-20-2012 12:03:44
216.158.161.19
 Re: jumpng solenoid fails to crank ( 1020 gas) in reply to husker44a, 06-20-2012 10:39:31
I am not sure I follow this logic. How is this different then starting it with the tractor battery? It is just a different battery.
Secondly if the starter motor is good but the solenoid is bad, how would the starter motor engage the flywheel. I thought the job of the solenoid was to mesh the flywheel and the starter motor together? What am I missing?
[Reply]  [No Email]
machinery-man
06-20-2012 12:25:41
98.93.82.37
 Re: jumpng solenoid fails to crank ( 1020 gas) in reply to Chris Tractor, 06-20-2012 12:03:44
Chris: Let me do a 101. The click you hear probably is the solenoid. Probably the contactors that the end of the plugger activate are arced to the point that you're not getting a power transfer of current directly from the battery. It sounds to me like you might want to get someone little more familar with the unit to check out as previous post gave a pretty good explanation and you may burn or blow up something if not careful to say the least get injured. Be safe.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
