Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: John Deere 80 Clutch Troubles.........
[Return to Forum]
Chuck McDonald
06-14-2012 17:06:17
208.103.220.66
Hi all,
I am currently disassembling the clutch on my John Deere 80. It looks very clean in there, but I can not get the solid driver disk off the splined shaft. I even managed to break out one of the puller bolt holes in the driver disk....bummer.
Any ideas?
This project all came about because the clutch would not release after I ran it the last time (three days ago)while loading on a trailer. I can roll the belt pulley and hear parts of the mechanism rattling around in the back of the pulley.
Thanks
Chuck
[Reply]   [No Email]
Chuck McDonald
06-15-2012 06:42:42
66.243.220.1
 Re: John Deere 80 Clutch Troubles......... in reply to Chuck McDonald, 06-14-2012 17:06:17
Brandon,
That's what i was doing when one side let go.
I guess i will just need to get longer bolts and try again.
Any ideas where to get a new driver disk if this one is not salvageable?
Thanks
Chuck
[Reply]  [No Email]
WeirdDeere
06-15-2012 11:55:52
199.87.176.108
 Re: John Deere 80 Clutch Troubles......... in reply to Chuck McDonald, 06-15-2012 06:42:42
I just wanted to be sure you were trying to get it off the right way. Those things can stick on there good sometimes.
I don't think I've seen any reproductions, your only choice would be salvage yards. I think I've seen one on Ebay too, though it was a bit spendy.
All the 80, 820, 830s use them, maybe the R, but not sure.
Brandon
[Reply]  [No Email]
WeirdDeere
06-15-2012 05:18:36
208.93.186.67
If you have a gear puller that will fit in the pulley, outside of the driver gear, that would be the best thing.
The service manual says to make a simple plate to slide two bolts through, tightening into the driver, then to push everything with a center bolt pushing on the crank bolt to pull off the driver...It works really well.
If one bolt hole is broke, you could try putting some pressure on it with the remaining bolt, and some not too hard smacking on the center bolt, or a little bit of head on the driver, it might pop loose, though a bit iffy as it's pulling crooked that way. Go for a puller if you can find one.
I'd be sure you're using the right size bolt that threads into the driver. I've grabbed the next size down once or twice and it wouldn't hold...until I looked at what I was doing! I'd thread it in as far as you can too, as there is a lot of force and you want it spread as much as possible.
It is different than Frank's 70. Both have their quirks. My 80 has a small chunk out of a driver thread, though it's still useable. On my 70 I ended up breaking the driver. It probably hadn't been off in decades.
Oh, make sure you have the driver and crank marked for position. It DOES matter on the 80, they counterbalance each other.
Brandon
[Reply]  [No Email]
F-I-T
06-15-2012 04:55:58
66.87.110.57
No books close at hand, but, if that driver is like the one on a 70D, those two bolts should be driven all way through so they push the driver off. They are not meant to just hold a pulley arm. Lots more meat if they are all the way through and seated.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
