Anonymous-0
On our JD 4630 we seem to be having issues where the hydraulics are slow but it seems like there is a leak somewhere internally. When raising the cultivator on the 3 pt hitch at about 1000 engine RPM it lifts slower than normal. WHILE raising the cultivator the engine SEEMS to be under less load from the hydraulic system than when the cultivator is fully raised. Question is, where is the most likely place on these tractors for an internal leak? I would also like to note that the steering seems hard sometimes. After cultivating for a while I took a temp gun to note hydraulic oil temps... transmission oil filter housing was 135 degrees, steering valve above the engine was 155 degrees, main hydraulic pump was 150 degrees... could there be an issue with steering valve? Any input would be greatly appreciated, thanks!
