| John Deere Tractors Discussion Forum |
Topic: 520 electrical problem
[Return to Forum]
| Author |
[Modern View]
| bigboreG
06-04-2012 20:44:27
216.51.248.99
I am trying to figure out a friends 520...it wont stay running unless you keep your foot on the starter pedal ALL the time. Just enough pressure to make a contact but not engage the starter to flywheel. When you let up, it backfires and dies right away. Before i knew it did this, we put in a new rotary switch. Wired it up the same way the old one came out. The lights work, the amp gauge shows a drop when switch is turned on, only thing is it WILL start with switch off. However, if it is running and you have foot on starter pedal, if you turn the switch to off, the tractor will die. I have messed with it a few times, he put a new starter in it 5 yrs ago. Everything looks good, no bare wires or signs of a short anywhere. His dad bought the tractor new and has since passed, id like to get it fixed up for him but just cant find the problem. Anyone have any ideas? |
| bigboreG
06-06-2012 20:30:06
216.51.248.99
Re: 520 electrical problem in reply to bigboreG, 06-04-2012 20:44:27
| Resistor did the trick! Thanks guys. Dealer had one in stock, guess we sell alot the parts guys said. Must be prone to problems. |
| machinery-man
06-05-2012 09:09:17
98.93.82.37
| The run wire goes to one end of the resistor ballast....wire comes from ignition switch to this this end other end to the coil. """"""Then""""" you have a wire from the coil side of the resistor block(actually) is just a connection...other end goes down to the starter switch so when you hit the foot petal activate the starter you will get a straight 12 volt to the coil on inital start up. When starter released power then is going through the ballast. Pretty simple. Having said all that I'd junk the whole thing and go to electronic ignition for a better start up and run condition for the tractor. Good luck. |
| 34gpa
06-05-2012 06:42:43
75.117.111.218
| It has a bad switch.I have 2 or 3 that will do excactly that.Look and see if the gas guage is moving when you turn on the switch,if not,the switch isnt working,or if the amp meter is showing a small discharge.The starter switch on the starter of the early ones has a small terminal that you run a wire from to the terminal on the resister going to the coil.It is energized when you step on the starter,and even though its not right,its the way it was designed.The tractor will run with the starter pedal pushed. Release it and it dies. So far I can turn the switch back and forth and it will make contact and work, or open it up and clean it,or put in a new one,bout $25,which would be the best.Look at the wireing dia. and you will see the small wire coming of the switch and going to the resister,check it for power,versus when you only have switch on |
| John T
06-05-2012 03:39:56
216.249.82.117
Open Ballast Resistor in reply to bigboreG, 06-04-2012 20:44:27
|  I agree with Larry and M Man.... If the ignition ballast resistor is bad/open or miswired, that will cause the condition you describe i.e. will run ONLY when starter switch is (at least partially) engaged. Its located between the ignition switches IGN output terminal and the coils input (NOT to distributor) terminal and should read in the vicinity of say 1.25 to under 2 ohms ID SAY ITS BURNED AND OPEN or else isnt wired correct in series between switch and coils input. ALSO NOTE with Ign switch OFF it shouldnt start and if it does theres a wiring problem in the safety circuit from MAG or GRND on the switch down to the coils output (to distributor) terminal. As M Man described even with a bad/open ballast (which dont allow normal ON voltage from switch to coil) she can run if the start switch is engaged cuz the start switch sends full unballasted voltage to the coils input while cranking to by pass the ballast for better cold weather starting... See M Mans wiring diagram http://img.photobucket.com/albums/v437/M-MAN/SM-2029/50-1-JPEG.jpg John T |
| LarrySTN
06-04-2012 21:00:05
71.54.95.232
| sounds like a bad ignition resistor. |
| M-MAN
06-04-2012 22:01:49
184.39.46.7
Re: 520 electrical problem in reply to LarrySTN, 06-04-2012 21:00:05
| X 2. She's running when the starter switch is pulled because it bypasses there to give 12v to the coil when cranking. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
