6420 Dash Problems
cgillis
New User
Hi I recently bought a 6420. WHen I go to start it and turn key to first position no sensor lights on top 2 rows come on at all. Digials display works fine as do the mechanical gauges. Tractor runs and operates fine. From my understanding all of these lights should come on for 1 sec when key is turned on. Does anyone know what the problem might be. Checked all fuses already. Could it be in the dash panel itself??
Honestly, I have NO clue about your tractor. That being said, a LOT of problems stem from poor grounds. Again, I know nothing of your unit, BUT, minor corrosion can screw up all the wonderful electronics that you may have. That is where I would start. Hope This Helps.
The lamp test is optional. You can choose to test it or not. Right now i don"t have it with me but I can see it for you later.
