Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: how much does calcium weigh in the rears?
02-20-2012 09:37:02
So 110 US gallons if filled to the max height of the valve stem. Some people try to fill higher but it just makes the tire harder riding and increases chances of a blowout. 8.34 lbs per US gallon with a density of 1.0 So 917lb or more depending on the strength of the salt solution. Depending on the use and application........Liquid ballast may or may not be required. The tractor will burn less fuel dragging 2000+lbs less weight around and have less rolling resistance. No messes either if a tire gets holed running dry or with diluted washer fluid.
