Leaking PTO shaft on 4020
ridgelane
If I replace the o ring on the pto shaft, will that take care of the oil seepage or is there another seal inside the assembly? It seems to leak when not in use and holds when the pto is used.
Thanks, I was afraid there would be more to it than a simple O ring change. I'll have a closer look at it and get the fix done.
