Well the engine is reinstalled & then I threw
in the new pistons, spent all day saturday
tinkering, fixing & install all the pieces &
parts. Cranked it over till the oil pressure
came up, as it cranked turned the igntion on
& full choke, Popped right off.. Let it run
for about 2 hours, while I tinkerd, put tools
away, installed more pieces & parts. I dies
everyonce in awhile so I gotta take the carb
back off & clean it out, so far it sounds good
except for the occasional stumble. I can tap
the carb or wiggle the adjustment screws & it
smooths back out. All new fluids in every
compartment, rewired complete machine,
installed used ampmeter that isn"t registering
even tho I know the gennie is charging. Looks
like it will require a New PTO seal?? Checked
all the gears, seems quiet, Brakes stops pretty
good.. Hydraullic stays up all nite.. Next is
the rear tires & wheels since I can see inner
tube between every tread bar, I can"t believe
they are still up? I promise there will be
pictures someday? LOL
Have a Great day!
Have a Great day!
