950 compact tractor hydraulics
ridgelane
I have a 1978, 950 JD compact tractor with the Yanmar engine. The tractor came with hydraulics to the three point hitch only. I am trying to find out where one can tap off the lines to add a control valve to the unit. Has anyone added a control valve to this tractor? I've asked at the dealership and no one has an answer.
(quoted from post at 01:03:16 09/03/11) I have a 1978, 950 JD compact tractor with the Yanmar engine. The tractor came with hydraulics to the three point hitch only. I am trying to find out where one can tap off the lines to add a control valve to the unit. Has anyone added a control valve to this tractor? I've asked at the dealership and no one has an answer.
I wonder why somebody couldn't turn to the parts book and assist you?
Need to know the serial number of the tractor.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
38 - SELECTIVE CONTROL VALVE LEVERS AND BRACKET
40 - SELECTIVE CONTROL VALVE HOUSING (CESSNA 30932 CAV)
41A - SELECTIVE CONTROL VALVE HOUSING (CESSNA 30932 CBH)
41C - SELECTIVE CONTROL VALVE HOUSING (DUKES FLUID POWER 1627-AN)
42 - 850/950 SELECTIVE CONTROL VALVE LINES (FIPS)
44 - 850/950 SELECTIVE CONTROL VALVE LINES
46 - 1050 SELECTIVE CONTROL VALVE LINES
48 - 1050 SELECTIVE CONTROL VALVE KIT
50 - QUICK COUPLER
53 - QUICK-CONNECT COUPLERS (PARTS FOR CONVERTING 1/4" TO 1/2")
Thanks, that was so simple the dealer should have thought of it.. I have the lower numbered tractor, where the square block is in the hydraulic line. I'm looking into the entire process and hopefully will have something on there shortly.
