Rob Maloney
Finally, finally, after months of head scratching and cussing I think my 2630 hydraulic problems are over (for now). Wife's step-dad and I pulled the rockshaft and put in new seals (it had a small chipped cavity inside the cylinder that he repaired with JB Weld). How this happened is beyond me. This stopped the misting under the fill cap. Secondly, he pulled the steering valve and rebuilt. Said it was a real pain in the buttocks. Had to "blindly" put in new shims that were busted as none of the manuals give instruction...even had a JD manual from a dealership. Why do these shims break? Can I count on this happening again in the near future? There was also a broken piston ring in the steering valve. Any comments or advice on these 2630 steering valves would be appreciated greatly. Should I think about trading this 2630 with loader while everything is working, or should I have a good tractor for years to come? This appears to be the downfall in an otherwise pretty solid tractor. Thanks.
