Rob Maloney
This is a follow-up to an earlier post about my 2630. I posted about hydraulic cavitation in my rockshaft and loader when the hydraulics were warm. Replaced the seals in the rockshaft--still had misting with 3 pt raised all the way, but it stops when depth control lever is set at "D". Second, had the steering valve rebuilt. There is a piston ring broken with about 1/2 inch of the ring missing. Put everything back together, no cavitation when warm, system working well...but now, no steering when sitting still. Had steering before, but had cavitation in steering wheel. Now the cavitation is gone, but I seem to have little or no power steering! My mechanic thought maybe the loader was too heavy for the tractor (JD 145) but I don't believe that since there are so many 2630/145 pairs out there. He also thought the the partially broken ring in the steering valve could be the problem, although he was doubtful that it would have much impact due to its design. Any suggestions before I start drinking? Thanks to everyone.
