Ireland.29
well guys, I"ve tried a load of different troubleshooting but still puzzled! ive made sure the fuel tank and lines and filter are clean and replaced fuel lift pump. also checked inside timing cover window of inj pump and no sign of any debris.. i opened return fitting on top of pump and no dirt present... the tractor runs for 25 - 30 minutes from cold at pretty high rpm and then starts revving up and down before eventually dying... it starts up ok again but problem comes back within a few minutes once hot.. the ring / rubber inside timing window is intact also. any ideas?
