Deere Kawa 14HP CARB NEEDED
Rob Berman
New User
Model of mower 245
Serial number M00245B162099
Engine number FC420V-F500 FC420VA99489
Carb part number AM117379
The tab on the float is broken, a rebuild kit will not fix the problem
Looking for help in finding a carb for this mower
One of the best kept but well known secrets is the JD parts section hidden on the JD web site.
Item #29 should a complete new carb float.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
CARBURETOR (MARKED 32218) (240, 245)™BR>CARBURETOR (MARKED 32218) (240, 245) (CONTINUED)
Cart KEY PART NO. PART NAME QTY ENGINE SERIAL NO. REMARKS
1 M74288 SCREW 1 PILOT AIR
2 M88544 COMPRESSION SPRING 1
3 AM109191 CARBURETOR KIT 1 PLATE & SCREW
4 ........ JET 1 PILOT (NO. 55) (ORDER AM118133)
5 M76326 RING 1 (K)
6 M88536 SCREW 2
7 M88550 RING 1 (K)
8 M88551 SEAL 1 (K)
9 AM109246 SHAFT KIT 1 CARBURETOR THROTTLE SHAFT
10 M94462 CLAMP 1
11 M96541 TUBE 1
12 M117604 NOZZLE 1 MAIN (NO. 73A) (NLA)
13 M117605 NOZZLE HOLDER 1 (NLA)
14 ........ JET 1 MAIN (105) (ORDER AM118133)
15 M88547 GASKET 1 (K)
16 AM109436 CHAMBER 1
17 M117551 WASHER 1
18 M120522 SOLENOID 1 (SUB FOR M117548)
19 M88543 SCREW 1
20 M88544 COMPRESSION SPRING 1
21 M88548 PIN 1 (K)
22 PT12064 CLIP 1
23 M73847 VALVE 1 (K)
24 M77143 JET 1 AIR (NO. 1.8)
25 AM109245 KIT 1 CARBURETOR CHOKE SHAFT
26 21M7230 SCREW 1 M4 X 14
27 M88544 COMPRESSION SPRING 2
28 M88557 SCREW 2
29 M76505 FLOAT 1
30 M70292 JET 1 PILOT AIR (NO. 1.1)
31 M88769 RING 1 (K)
32 M115066 WIRING LEAD 1 (NLA)
33 M149301 CLAMP 1 (SUB FOR M70076)
34 M77484 RING 1
35 M76503 SPRING 1
36 AM117379 CARBURETOR 1 (NLA)
.. AM118133 KIT 1 JET (NLA) (INCLUDES PILOT JET NO. 55, MAIN JET NO. 105 AND HIGH ALTITUDE JETS NO. 100 AND NO. 102.5)
.. AM116355 CARBURETOR KIT 1 CARBURETOR REPAIR (INCLUDES PARTS MARKED WITH (K))
It"s not the float, it"s the piece that holds the float in place. ie the casting.
Ahhhh.....a picture is worth a thousand words.
That is a dilemma.Done things like that myself.
It's a wild guess but Deere lists a complete carb for the 260/265 models ?
Perhaps the main body is the same/similar and the metering/linkages from the 245 carb could be transplanted?
AM109450 CARBURETOR
