Hi all, I need a little help with a 9250 backhoe swing pin and bushings. I was on this board a few times when I had a Case 480 a few years ago, but it"s been a while since I had a tractor...But I just bought a 300b tlb.
The pin I"m working on is the one the swing links pivot on, tapered at each end. It"s listed on the parts diagram as "Pin, inner swing links to main frame", number 10, JD PN U43184.
I bought the machine with that pin out. I"m trying to reassemble everything now, but all I have are the pin and link spacer.
The pin looks OK, so I don"t think I need that (I didn"t mic it, just no observable grooves or inconsistent surfaces).
Long question shortened; is there an alternate source from JD for these special parts? JD"s prices are really tough to bite on.
I need 2 of each:
19H2717
U43180
U43179
U43163
Are there TLB junkyards I can call for them? Are these parts worth buying through JD, or OK getting from a junkyard machine?
Thanks for any info!
I need 2 of each:
19H2717
U43180
U43179
U43163
