| Author |
[Modern View]
| JOHN ALMOND
05-04-2011 13:31:26
64.12.117.12
I am looking for a replacement engine. Any sort of thoughts what could replace it??? I hear that some bob cat engines would work. Which ones??? Would it run well? I appreaciate any and all help. I move round bails to feed the animals with my tractor and need it soon. I also do all the mowing with it. |
| Tx Jim
05-06-2011 04:44:24
67.142.163.22
Re: 950 John Deere with a cracked block in reply to MDM, 05-04-2011 13:31:26
| John
Try this salvage yard
Worthington Tractor Salvage Rt.4, Box 14 Worthington,Mn 56187 1-800-533-5304 |
| Tx Jim
05-05-2011 13:24:26
67.142.163.31
Re: 950 John Deere with a cracked block in reply to kola, 05-04-2011 13:31:26
| john almond
05-06-2011 03:54:01
170.99.13.89
Re: 950 John Deere with a cracked block in reply to Tx Jim, 05-05-2011 13:24:26
| Northern Baltimore County in Maryland |
| Tx Jim
05-05-2011 10:28:25
67.142.163.29
Re: 950 John Deere with a cracked block in reply to buck eye al, 05-04-2011 13:31:26
| Quoting Removed, click Modern View to see
b&d
I been on here every day just hadn't seen where you were trying to persuade posters into doing something that you won't/can't do as in buy one of the new tractors. I'll remind you again that this is an antique tractor forum. :lol: :lol: :lol: |
| john almond
05-05-2011 10:48:40
170.99.13.89
Re: 950 John Deere with a cracked block in reply to Tx Jim, 05-05-2011 10:28:25
| I just want to have my tractor back. It did every job I ever asked it to. I don"t need a new one just need the 950 john deer engine or what ever would replace that and work well. I appreaciate any and all help. Thanks very much. I have a talented friend who can do the work for me so we are good in that department. |
| buickanddeere
05-05-2011 10:59:11
192.75.48.150
Re: 950 John Deere with a cracked block in reply to john almond, 05-05-2011 10:48:40
| What is failed and broken? The block and/or sleeves? Was it freeze damage or run out of oil and put a rod through the block? How much are you planning to pay for repairs? |
| Tx Jim
05-05-2011 05:32:16
67.142.163.28
Re: 950 John Deere with a cracked block in reply to greenday, 05-04-2011 13:31:26
buickanddeere
I suppose your new JD tractor is scheduled for delivery??????? YEA RIGHT!!!!!!!! I suppose you're not recommending for someone to buy a new JD when you won't or can't. |
| buickanddeere
05-05-2011 05:55:48
192.75.48.150
Re: 950 John Deere with a cracked block in reply to Tx Jim, 05-05-2011 05:32:16
| | txjim, good to see you back. I was getting worried when you had not promptly responded. My tractor still runs so replacement is optional. When the time comes when having to choose between spending more than what it's worth on repairs. It's gone and new/nearly new will be purchased. Parts and labour repairing the 950 is going to cost as much as trading the busted 950 for a new 2WD 3005. We are not comparing here Waterloo 50/55/60 series with those new and overly complex commmon rail Tier III & Tier IV tractors. I agree keep the 50/55/60 series Waterloo's running. If purchasing a small 2000,3000,4000 or 5000 series tractor. Do it quick before they are converted from mechanical injection to common rail emissions before the end of 2013. Manufactures are going to Tier IV now rather than rushing at the end of 2013. |
| Jake Winn
05-04-2011 21:14:08
207.200.116.66
Re: 950 John Deere with a cracked block in reply to JOHN ALMOND, 05-04-2011 13:31:26
| Is it a water crack? Where is the crack? Could it be repaired? |
| gidtex
05-04-2011 17:05:41
144.191.148.3
| paige tractor has one, paige texas ask for larry |
| buickanddeere
05-04-2011 14:39:22
216.183.138.121
| | Assuming it's the 950 compact tractor and not the Timberjack. CH18171 SHORT BLOCK ASSEMBLY CH18173 CYLINDER BLOCK (INCLUDES PARTS MARKED (B)) (NLA) Price when new back in 1988 Original price (USD): $12,000 Production: 1978 - 1989 Compact Utility tractor Distributor: John Deere Manufacturer: Yanmar Factory: Japan John Deere 950 Power: Drawbar (claimed): 23 hp [17.2 kW] PTO (claimed): 27 hp [20.1 kW] Drawbar (tested): 22.12 hp [16.5 kW] PTO (tested): 27.36 hp [20.4 kW] power test details ... Mechanical: Chassis: 4x2 2WD 4x4 MFWD 4WD (optional) Steering: manual power optional Brakes: differential mechanical expanding shoe Cab: ROPS.
You have to figure what the tractor is worth as is? Worth after restoring to operational condition a 23-33 yr old tractor with how many hours and how much wear? All and total costs to return to operational condition. Price of new replacement with no wear, no previous abuse and full warranty? One has to run the numbers and figure what in your personal situation is cheapest in short and long term. If it's freeze damage, what else is busted? Repair or sell/trade and purchase? There is no perfect solution, all are compromises. 4X4, 41HP under $16,000 http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=4005%20LV&displayModelName=4005%20Compact%20Tractor%20(41.5%20hp)&tM=HO&pNbr=1460LV 2WD 27HP $11,000 http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=3005%20LV&displayModelName=3005%20Compact%20Tractor%20(27%20hp)&tM=HO&pNbr=1450LV |
| John730D
05-04-2011 14:21:57
208.73.228.5
| Google Salvage Yanmar Engines. Lot of hits. Will need to know your engine number. |
| john almond
05-04-2011 16:41:02
64.12.117.12
Re: 950 John Deere with a cracked block in reply to John730D, 05-04-2011 14:21:57
| It is owned by one family, not too many hours on it. Routine mowing, moving hay bails out to the animals, some snow plowing. It ran like a million dollars. It leaked oil where I didn"t notice it. I am not a engine mechanic person. My fault. 2 wheel drive, but everything else works awesome. |
| buickanddeere
05-05-2011 05:31:53
192.75.48.150
Re: 950 John Deere with a cracked block in reply to john almond, 05-04-2011 16:41:02
| Where and what exactly is broken? Pictures can be posted here via photobucket. Model # of the loader? |
| Dan in North Houston
05-04-2011 13:38:38
38.100.70.66
| Check the Austin Texas Craigslist, there is a parts tractor that appears to have a good motor. |
| JOHN ALMOND
05-04-2011 13:42:30
64.12.117.12
Re: 950 John Deere with a cracked block in reply to Dan in North Houston, 05-04-2011 13:38:38
| Thanks so very much. Shipping is probably a fortune... I will look into it. Thanks again |
| buickanddeere
05-05-2011 13:47:30
216.183.138.121
cross reference info in reply to JOHN ALMOND, 05-04-2011 13:42:30
| Don't know exactly which engine series Yanmar used in those 950's but here is the current Yanmar of similar displacement. And another Yanmar of similar power. Can't hurt to checkout the JD short block.Sometimes some JD parts are surprisingly reasonable in price. http://www.yanmar.com/products/industrial-engines/liquid-cooled/tnv/variable-speed-engines/3tnv88-bdsa/ http://www.yanmar.com/products/industrial-engines/liquid-cooled/tnv/variable-speed-engines/3tnv82a-bdsa/ |
