1530 Hydraulics
Rob NC
Does the 1530 have the hydraulic capacity to handle a loader ok and can one tap into the main supply line like I've heard about for the larger tractors ?
Yes they do okay with a loader, and you can tap in on the lower right side under the floor board, and return through the filter housing
As Tim stated the correct place to get supply oil for a loader on a 1530 is at the rear of the pressure control valve down by hyd filter. This is the same place that supplies SCV if so equipped.
