Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
John Deere valve adjustment
dieselhotrodder
11-26-2010 20:06:42
i need help on setting my john deere H valves... can anyone tell me step by step easy instructions on doing so?
Mark Poss
11-27-2010 07:49:58
 Re: John Deere valve adjustment in reply to dieselhotrodder, 11-26-2010 20:06:42
With tappet cover and both spark plugs removed, turn flywheel until left hand (No. 1) piston is at end of its compression stroke (L.H.IMPULSE@mark) and adjust both tappets on the left hand side, Turn flywheel until right-hand (No. 2) piston is at the end of its compression stroke (one half revolution from above) and adjust both tappets on right hand side. Tappets should be adjusted between 0.017 and 0.018 inch room temp. Hope this helps you, Mark.
gtx1967jewison
11-27-2010 05:24:27
your a diesel hot rodder lol & u cant adjust valves on an engine? crank it to firing position & set em for about 20 thou with a dial indicator, or just till you feel slight fore-aft movement in the pushrod is fine. its not a high tech engine.
dieselhotrodder
11-27-2010 06:26:54
 Re: John Deere valve adjustment in reply to gtx1967jewison, 11-27-2010 05:24:27
I did not ask for a smart remark. Just a simple hand in doing it right.. I do believe that this forum is for decent people who are trying to help
Kent Petersen
11-27-2010 13:00:33
 Re: John Deere valve adjustment in reply to dieselhotrodder, 11-27-2010 06:26:54
Diesel dont pay any mind to jewlson he mostly does not know must
dieselhotrodder
11-27-2010 06:26:52
Copyright © 1997-2015 Yesterday's Tractor Co.
