TractorLinks.com
Show Parts for Model:
convert 1000 rpm pto to 540 rpm on john deere 4630
chris knight
03-31-2010 19:52:53
I'm really looking for a way to convert my john deere 4630 tractors pto from 1000rpms to a 540rpm pto. if so how and where could i find parts of the conversion kit for it
Heat Houser
04-01-2010 17:55:56
 Re: convert 1000 rpm pto to 540 rpm on john deere 4630 in reply to chris knight, 03-31-2010 19:52:53
You can purchase a spline adaptor to get from 1000 splines to 540 splines. You then run 1200 on the tach and your PTO will be running at 540. If you need a high horsepower 540, this will not work. The engine is gutless at this RPM as you are below peak torque.
buickanddeere
04-01-2010 04:52:07
It would be cheaper to trade the 540rpm pto equipment for 1000rpm. That is would be to have custom gears cut for the 4630. There is an external changer gearbox which also requires a longer drawbar.
Tim S
03-31-2010 20:09:03
Hub City usto make a gear box to adapt them, it moved the shaft back some,,we looked into it back in the 70's for our old 4630 (new then),,i'm not sure if they are in business anymore, or if any are around,,I have never seen one up close, just pic's...
chris knight
03-31-2010 20:24:49
 Re: convert 1000 rpm pto to 540 rpm on john deere 4630 in reply to Tim S, 03-31-2010 20:09:03
thank you
44 Diesel Tech
03-31-2010 19:59:01
Walked around my boss's 4520 that he bought at auction in the US. and found 1000 mid pto and 540 rear. I need to check into it further.
This post was edited by 44 Diesel Tech at 20:02:42 03/31/10.
