What is the best way to go about cutting off an axle off of an Unstyled A? Its on a parts tractor and its got a 12 spline hub stuck on it that I need. I've bent my 3/4 inch plate puller trying to pull it and snapped 2 breaker bars torquing the bolts. Been spraying with oil for 3 weeks now. Hub hasn't budged. Next step is to press it off, hence getting the axle off.
The tractor is sitting on the ground, or else I would drain the rear end and remove the cover and slide out the whole axle. Since I can't do that, cutting seems to be the last option. If you have any ideas other than a big torch I'm most interested in those.
Thank You
Thank You
