1 AW23292 FRAME 1 X R.H.
2 14H1039 NUT 12 X 5/8"
3 12H294 LOCK WASHER 6 X 5/8"
4 24M7241 WASHER 4 X (SUB FOR W21684) 2840, 2940, 3130, 3140 (-379305)
5 W21684 WASHER 4 X 2940, 3140 (379306-), 2950, 2955
6 03H1856 BOLT 4 X 5/8" X 2-1/4"
7 03H1856 BOLT 4 X 5/8" X 2-1/4"
8 14H1058 NUT 20 X 3/4"
9 W33561 BRACKET 1 X 2940, 2950, 2955, 3140 (WITH SOUND-GARD BODY)
10 19M7724 CAP SCREW 3 X M10 X 45
Cart KEY PART NO. PART NAME QTY SERIAL NO. 148 158 168 REMARKS
11 14M7296 FLANGE NUT 3 X M10
12 AW23293 FRAME 1 X L.H.
13 12H236 LOCK WASHER 8 X 3/4"
14 19H3066 CAP SCREW 8 X 3/4" X 2"
15 19H3516 SCREW 2 X 5/8" X 1-3/4", 2840, 2940, 2950, 2955, 3130, 3140
16 19H3516 SCREW 2 X 5/8" X 1-3/4", 2940, 2950, 2955, 3140
17 19H3426 SCREW 2 X 5/8" X 3-1/2", 2840, 3130
18 19H3426 SCREW 2 X 5/8" X 3-1/2", 2940, 2950, 2955, 3140
19 19H1734 CAP SCREW 2 X 5/8" X 2", 2840, 3130
20 19H3587 SCREW 2 X 5/8" X 4-1/4", 2940, 2950, 2955, 3140
21 19H3587 SCREW 2 X 5/8" X 4-1/4", 2840, 3130
22 AW16325 CROSSBAR 1 X
23 19H1847 CAP SCREW 4 X 5/8" X 2-1/2"
24 24M7047 WASHER AR X 13 X 24 X 2.500 MM, (USED TO LEVEL STEP)
25 E56554 SPACER 1 X 10 X 40 X 50 MM (USED TO LEVEL STEP)
1 14H1058 NUT 20 X 3/4"
2 24H1396 WASHER 12 X 25/32" X 1-1/2" X 0.105"
3 T32429 STRAP 8 X (B) 2840 (-302479)
T32429 STRAP 4 X (B) (C) 2840 (30247
4 T32480 PLATE 2 X (A) 2840 (-302479), 3130 (-300668)
5 W28306 PLATE 4 X X (B) (C) 2840 (-302479), 2940, 2950, 2955, 3140
W28306 PLATE 2 X X (B) 3130 (-300668)
6 14H1040 NUT 8 X X 1/2"
7 12H301 LOCK WASHER 8 X X X 1/2"
8 AW21803 PLATE 2 X (A) 2840 (-302479), 3130 (-300668)
AW21803 PLATE 2 X (B) (C) 2840, 2940, 2950, 2955, 3130, 3140
AW21775 PLATE 2 X (A) 2840 (302480-), 2940, 2950, 2955, 3130 (300669-), 3140
9 L34163 CAP SCREW 2 X (A) 2840 (302480-), 2940, 2950, 2955, 3130 (-300668)
R53100 CAP SCREW 2 X (A) 3130 (300669-), 3140
R54542 CAP SCREW 2 X (A) 2840 (-302479), 3130 (-300668)
W32662 BOLT 2 X (B) 3/4" X 13", 3130, 3140
10 R48139 CAP SCREW 4 X (A) 2840 (-302479), 3130 (-300668)
R44529 CAP SCREW 4 X (A) 2840 (302480-), 2940, 2950, 2955, 3130 (-300668), 3140
08H4811 BOLT 4 X (B) 3/4" X 10", 3130, 3140
08H4811 BOLT 8 X (B) 3/4" X 10", 2840, 2940, 2950, 2955
08H4811 BOLT 8 X (A) 3/4" X 10", 2840 (-302479)
08H4811 BOLT 8 X (C) 3/4" X 10", 2940, 2950, 2955, 3140
11 W30770 U-BOLT 4 X (SUB FOR W28290)
(A) TRACTOR WITH ROLL-GARD
(B) TRACTOR WITHOUT ROLL-GARD
(C) TRACTOR WITH SOUND-GARD BODY
1 AW20617 FRAME 1 X
2 14H1039 NUT 10 X 5/8"
3 12H294 LOCK WASHER 10 X 5/8"
4 19H1734 CAP SCREW 4 X 5/8" X 2"
5 AW16325 CROSSBAR 1 X
6 03H1856 BOLT 2 X 5/8" X 2-1/4"
7 W30306 STRAP 2 X
8 24M7241 WASHER 4 X (SUB FOR W21684)
9 19H1708 CAP SCREW 2 X 5/8" X 1-3/4"
10 14H1058 NUT 20 X 3/4"
11 AW20618 FRAME 1 X
12 19H1824 CAP SCREW 4 X 5/8" X 2-1/4"
13 W28355 BRACKET 1 X
14 19H1862 CAP SCREW 4 X 3/4" X 2-1/2"
15 12H236 LOCK WASHER 12 X 3/4"
16 19H3066 CAP SCREW 8 X 3/4" X 2"
17 W33561 BRACKET 1 X (USED ON 2940, 2950, 2955 AND 3140 TRACTORS WITH SOUND-GARD BODY)
18 19M7724 CAP SCREW 3 X M10 X 45
19 14M7296 FLANGE NUT 3 X M10
