36 or 38 inch Tires
1 Dollar
Are there any advantages to 12.4-38 inch tires over 12.4-36 inch tires? They would be on a John Deere A. I have 36's right now but have a broken wheel. I can't decide whether to find another matched spoke wheel or replace what I have with 38 inch hardware.
Anybody have any 38 inch tires for sale?
Thank You
If the cast center hub is cracked on your 36" spoke wheel, as many did, there is a generally accepted repair. Make, or have made, a 3/4" steel ring with the bolt pattern drilled in. Install the ring between the bolts/lockwashers and the cracked wheel hub. Make sure you replace the original bolts with new grade 8 bolts that are 3/4" longer. This is in one of the publications I have. I cannot remember which. The repair looks nice in the example in the book, especially after paint. It is not original but neither is changing to 38 inch wheel equipment.
HTH
Mark
