JD STX38 Wiring Diagram
JimBee
New User
Does anyone have a wiring diagram for a John Deere STX38 with the yellow deck. My mower starts and runs but when I flip the switch to engage the blades they do not engage, so I"m trying to trace down the wiring and see if I can find the problem.
Thanks, Jim
Take a test light to the switch, see if the electricity comes out the other post when the switch is flipped. I'll bet that the electric pto clutch is bad.
I bought this JD used so I"m not sure of the complete S/N but these are the numbers I have:
John Deere Product Identification Number
*STX38B_01_ _81*
STX38 Tractor
and on the engine:
Koehler 12.5 HP
Model CV12.5S
SPEC NO 1215
S/N 1924903858
Thanks for the Help
JimBee
Jim, without all the serial number digits I'm doing a bit of guessing, but I believe this the right one, please compare the wire colors to be sure
OK, thank you very much, I should be able to trace things down fairly easily with this, I"m sure this saved me several hours of "now where did the yellow one go again" etc. I"ll let you know how it turns out. Thanks again, JimBee
