rims for 1952 'A' question
Anonymous-0
I am getting wider rims for my '52 A and I was wondering if the double bevel rims will work? The ones that I have on now have a 3 inch rib (roughly) in the middle and it is clamped to the wheel/hub piece by a sort of clamp piece (thats tightened by a nut).
if anyone knows what Im talking about, please let me know if the double bevel rims will work. thanks
Dane
if you are talking bout double bevel likes on a 60 or 70 then no but if your talking double bevel likes on a dc case or farmstall m then yes
Anyone have a set of 11" rims (from an "A") in Ohio..??
I want a set for my "B" so I can go with 13.6x38" tires..
Thanks...
Ron.
Thanks...
Ron.
G rims will fit and are 1 inch wider for 12-38 (13.6-38 now) tires. Some of the very last A's came with these rims and 12-38 tires. Other wise you can get 14 inch rims that will fit from Miller Tire, but nothing from later model tractors like the double clamp ring bevel types will work. You have to have the older 2 step drop center type rims.
