need 4010 wiring diagram
travz500
where can i get a wiring schematic for a 4010 diesel? our dealer not very helpful for little stuff keep asking and they forget to fax it us thanks for your help
it does help considerably but the diagram that shows the lights is different my key switch has more than two terminals and two wires know where i can get one that will match it will help me for the wires i need to trace for now i really do appreciate this it is service with a smile i assume you are smiling
Not from me. My web page is about hydraulics.
The SM2039 has a good wiring diagram. The I&T manual has a very poor wiring diagram. The wiring of a gas and a diesel are a lot different, the diesel being more than twice as complex.
Gerald J.
travz500: Take a look at the wiring diagrams again. The first and the third ones show all the wires on the key switch (more than 2). If you happened to open just the second diagram (scanned from the Deere shop manual), it just shows the 2 hot wires on the key switch since it is showing mainly the lighting circuits.
If you are trying to trace wires from the key and/or light switch you will need to refer to both the third and forth diagrams to see where all the wires end up.
Good Luck: gwece
John Deere 4010 Diesel Wiring Diagrams
