Lower water pipe for 50
Rob NC
Are new lower water pipes available for a 50? I've looked around at different sites and can't seem to find one. Thanks
I think the lower may not be a wierd size ? so maybe exhaust tube can be made work. I bought some tube from K & K antique tractors for my upper pipe on a 50.
Rob,
The hose the pipe fits into has an ID of 1.875, and common 1 1/2" schedule 40 pipe has an OD of 1.900", so that should be a good fit. use a little oil and it should slip right on - the 0.025" difference should not be a problem.
