Rob in Yukon
New User
First off, thanks to Chris for helping with password retrieval.
I have a 440B powershift skidder. Last fall I replaced the charge pump with a used one. That's all I could find. It seems to be performing well, but the machine suddenly lost most of the hydraulic power the other day. After some troubleshooting, I changed filters, drained the transmission and cleaned the sump screen checked the filter relief valves and found the trans. filter relief was missing the spring guide and the valve is stuck up so not relieving. I order a new guide and sensor/plug. Not wanting to wait, I continued on and checked out the stroke control valve and reset the standby pressure. All is more or less normal again, the filter relief must have been stuck for a long time before I got the machine. I have three questions. One, the standby pressure is the same at idle as at the spec'd 2500rpm. Is this normal? On another post I read that the charge pressure can be checked at the lower 3/8 port on the stroke control housing. Can this be used as an alternate to the CLUTCH test port?
Blade function slows when steering so I will check out the pressure control valve today and then bleed the steering valve, warm her up and try again. I'm wondering about pump volume but don't have test equipment to check that. Any ideas or opinions on this?
I'm not a mechanic, but a logger and operator with tools and bush repair experience so I appreciate the expertise that many of you are willing to share.
