'41 A Oil on flywheel
JDBob
03-13-2000 07:14:10
Anyone have any idea why my '41 A would sling oil on the outside of the flywheel?
Is there some kind of seal or packing behind the flywheel that needs to be replaced?
Thanks,
JDBob
Ron B.
03-13-2000 09:51:16
 Re: '41 A Oil on flywheel in reply to JDBob, 03-13-2000 07:14:10
Also be sure to center the flywheel spacer cover (the one taken off to replace the seal) on the flywheel spacer with a feeler guage.
John T
03-13-2000 09:33:01
Bob,yes hes right u need a new cork crank seal and get a new gasket for that D Shaped cover also because you have to remove it to get to cork seal and soak it in oil before you install it then get flywheel back on in time and at propeer end play clearance. Ol John T in Indiana
STMTS
03-13-2000 07:37:50
Yes,there is a cork seal behind the flywheel.JD still has them.You will need a flywheel wrench to remove it
Dave Kolby
03-14-2000 16:33:00
 Re: Re: '41 A Oil on flywheel in reply to STMTS, 03-13-2000 07:37:50
Never did have a flywheel wrench myself. Used a big ole pipe wrench, always works. Be darn sure you get those timing marks lined up right when you put it back on. If you don't know how to do that I can fax or e-mail a copy of the set-up for it.
Dave
