John deere 955 model 7 Backhoe
Jaystone10
05-04-2008 20:44:53
anyone in oklahoma have a John Deere 955 with model 7 backhoe looking for pictures
bought a #7 backhoe off a 750 and think the only difference is the mounting brackets which i can cut weld if need be and i need a power beyond kit not sure which kit to buy or if i need
F-I-T
05-05-2008 04:16:59
 Re: John deere 955 model 7 Backhoe in reply to Jaystone10, 05-04-2008 20:44:53
As to the "Power Beyon" kit, yes you need that. It supplies high volume hydraulic pressure to the hoe. I think you need kit number BM16763, which is a whole goods package (talk to your saleman because it's not priced in the parts scetion under that number). I thought the #7 was a subframe mounted hoe, though I am not entirely certain. There is a kit listed for that, # TY20367, and an additional 955 rear mount as well. You can get a lot wrapped up in the mounting brackets, but if you do it poorly, you can wreck that aluminum case on the tractor, so be careflul.
HTH
Frank
