John Deere 400 backhoe
Bill in Mass
05-24-2006 10:38:46
I am looking at what appears to be a early 1960s JD 400 diesel backhoe. Is there a place on the web where I can get the specs on this baby? Any comments on this machine, the motor it would have in terms of longevity and power? Are parts still available? Any comments are welcome.
Thanks!
Bill in Mass
05-25-2006 10:20:11
 Re: John Deere 400 backhoe in reply to Bill in Mass, 05-24-2006 10:38:46
How capable is the hoe at removing stumps? At motoring itself around? I used to have a Case 580CK hoe and the torque converter was a nightmare. Have you replaced the clutch on yours? The one I am considering has blue primer under the yellow paint as does one of the machines pictured on teh wierddeere website. was the blue paint a primer?
Thanks for all the information!!
Glen in TX
05-25-2006 09:28:45
Also the 202 can be updated with 219 parts. Same engines in the 2510 and 2520 ag tractors.
ABC
06-01-2006 03:30:24
 Re: John Deere 400 backhoe in reply to Glen in TX, 05-25-2006 09:28:45
Does anyone know the correct Diesel Injector # for a 1967 JD 400?
Tom in Central Pa
05-24-2006 11:11:34
I"m still using one, NOT an orphan, many of the parts/designs were used up until the Deere 310-C, 410-C came out. Very reliable, very repairable. Some AG parts are interchangeable.
202cu. in.4 cyl. diesel engine. 59H.P.@2500rpm.
Hyd wet clutch reverser.
8fwd. 4rev. gears
closed center, constant pressure hyd.@2250psi
Glen in TX
05-24-2006 11:09:26
Parts should be available through JD and may have to go through a industrial dealer. http://jdparts.deere.com and industrial manuals from JD at www.jdtechinfo.com 866-213-3373. If we're talking about the same backhoe find some info on the Weird Deere site.
