Re: Fuel Pump Fuse Location - John Deere 425 AWS
Bob
04-08-2006 18:14:29
For tractors THROUGH serial # 070,000:
Link
(Key #43)
For tractors AFTER Serial # 070,000
Link
(Also, key #43.)
J D Lambright
04-08-2006 20:12:08
 Re: Fuel Pump Fuse Location - John Deere 425 AWS in reply to Bob, 04-08-2006 18:14:29
Thanks for the info. I located those drawings several days ago, but they don't show just where on the tractor the fuse is located. I've tried tracing the wires, but I still can't locate it. I may have to take the 60 in. mowing deck off and see if the fuse is underneath the chassis next to the frame.
Bob
04-08-2006 20:29:51
 Re: Fuel Pump Fuse Location - John Deere 425 AWS in reply to J D Lambright, 04-08-2006 20:12:08
If the drawing is at all correct, it appears to be a 10 Amp "ATO" fuse attached to leads that "break out" of the wiring harness with a LOT of others, likely ahead of the dash, down near the module attached to the ignition switch.
J D Lambright
04-09-2006 08:50:10
 Re: Fuel Pump Fuse Location - John Deere 425 AWS in reply to Bob, 04-08-2006 20:29:51
Yes, that's where it would appear to me to be as well. I have looked everywhere in that area, and just don't find it. I'm headed out in a few minutes to take yet another look.
I appreciate your assistance.
