Walton Tedder
John Webb
06-22-2005 19:14:20
I picked up a used 3-point Walton hay tedder and can't understand the why the wheels are not made to swivel. Being 3-point, when turning the tractor, the wheels slide sideways, almost to the point of pulling the tires off the rims. Lifting the wheels slightly off the ground doesn't work in my bumpy fields. What am I missing here???
Hay Dr
06-23-2005 06:18:32
 Re: Walton Tedder in reply to John Webb, 06-22-2005 19:14:20
third party image
Some late 1980's model Walton WT-8 tedders had swiveling wheels. They went away from that because operators were not watching the positions of the wheels when they set the tedders down and would damage the tedders. If you have a 3 point fixed wheel tedder you need to tedder in somewhat straight lines and lift the tedder if you turn at the end of the field. Also part of the problem with this unit is the 350x6" tri-rib tires on the early Walton (Galfre')tedders. These tires dig into the ground and do not slide. The later tedders went to a 15x6x6 smooth tire that works much better. If your tedder tines (blue & white) are mount on a pipe you have either a WT8 or WT13. If your tines mount on a flat bar you have a WT-9. Walton only imported these sizes in 3 point.
Currently the WT16(14') & the WT21(17') are sold in pull type manual and hydraulic fold. The Hydraulic fold Walton's do not work as well as other brands like Sitrex, Tonutti, Vermeer,ETC. because they were not designed with the proper folding drives and joints.
Pictured is a used Walton WT21 manual fold.
No.2
06-22-2005 23:28:00
I should know this. We started with a 3-pt walton that I traded for a pull type. Both were two baskets and the wheels swiveled on the 3-pt and not on the pull type. There may be a way of locking and unlocking the wheels on them because I think the working parts of both machines are the same.When I went back to deal on a pull type the dealer ask if I just wanted to switch over to a pull type but I had already sold the 3-pt tedder.
BobMo
06-22-2005 19:46:37
Something wrong here they should be bogie wheels maybe thats the reason it sold. Ask the guy you got it from..... .....
