3pt. Sickle bar mower question
TD 2020
10-20-2004 14:49:11
I would like to purchase a used 3pt. sikle bar mower to cut ditch banks from the top down. That would require a mower that can swing approximately 45 degreees below the level position. Which mower should I look for? Some of the ones I've seen only go down to a level position. I would also like one I can still find parts for.
Robert in W. Mi.
10-21-2004 14:57:51
 Re: 3pt. Sickle bar mower question in reply to TD 2020, 10-20-2004 14:49:11
I have a NH 451, it seems to be bullet proof!!! Looks to be built to last forever, and mine just keeps on going.
I use it to cut ditches, and also to mow the banks on my ponds, i can run the sickle under water, and cut everything off at the bottom, even small trees.
Very good mower,
Robert
Hay Dr
10-22-2004 07:00:16
 Re: 3pt. Sickle bar mower question in reply to Robert in W. Mi., 10-21-2004 14:57:51
The NH451 sicklebar mower is the industry standard that all other single action sicklebar mowers are compared too.
Scott-IA
10-21-2004 07:21:03
We use a Ford 501 mower that we use to cut ditches with. I have no problem with it running well below or above the tractor even with the pitman stick. One word of advice. Weld a brace onto the pick up arm (for the lack of a better term). This is the arm that has two ball joints on it. I finally straightened ours enough that I welded a chunk of 1/2" axle to it to keep it from bending. So far it's worked flawlessly. That arm costs in the $150 range I think.
Sid
10-20-2004 19:05:33
The Allis Chalmers twin wheel drive would cut straight up or below level. I am not sure it would cut below level at a 45 degree angle or not. I have not seen a three point model but I understand they did make them.
Sid
10-20-2004 19:04:37
Older Man
10-20-2004 18:53:54
TD, I have a M F 41 Dynabalence that will cut at an angle below level. It is belt driven. I also have one to sell. Allen
td 2020
10-21-2004 14:59:52
 Re: 3pt. Sickle bar mower question in reply to Older Man, 10-20-2004 18:53:54
Where are you located and how much do you want for it. Does the MF come in an 8' model? What iss the advantage of a belt driven mower?
Leland
10-20-2004 21:01:52
I agree with old man those massey are great mowers used one many times.
Leland
10-20-2004 21:00:27
