TractorLinks.com
Pull Behind Brush Hogs
Martin Miller
12-03-2003 16:07:58
I have about 35 acres of flat open fields. The past to years my dad and I have mowed the fields with an Agri-Fab motorized pull behind brush hog. The fields are nice grass with no bushes etc. However in some spots the fields are rough. I have been looking to buy a 5-6 foot pull behind brush hog for my tractor but before I do I would like to know how well they work? Any help is appreciated.
Huckleberry
12-05-2003 08:54:59
 Re: Pull Behind Brush Hogs in reply to Martin Miller, 12-03-2003 16:07:58
I have both a pull type and a mounted. Both work good. one thing on the mounted---make sure you double nut your hitch bolts, stay away from 'quik-clips'...you could get in a real mess if one side of the mounted gets loose. Be Careful.
Robert
12-04-2003 09:55:57
When I was given my '45 JD "A", I was also given a 6' FMC pull behind brush hog. I like it just fine. The drawbacks that others have mentioned (backing, etc.) are there, to be sure, and the extra length of a fairly long tractor (mine has a tricycle front)with the mower means I have to "plan ahead" when turning, but mowing is not a problem.
Kurt : Ky
12-03-2003 19:37:59
mowing fields like that a pull type will work just fine.get and good band one and not some off the wall name mower.
wolfy
12-03-2003 18:35:57
Pull behind brush hog is BY FAR your best choice. You can definitely make better time with the pull type. Any turning with a 3-pt mower has the mower moving a bit sideways - they just don't cut well sideways! I've used both types a lot - own both types; the 3-pointers don't get taken to the big jobs. Cut 60 acres of pasture every year-steep, rough, odd shaped, banks, etc. Always take the pull-behind that day!
old
12-03-2003 16:16:24
They are ok but if you have 3 point they are even better.
Martin Miller
12-03-2003 16:48:55
 Re: Re: Pull Behind Brush Hogs in reply to old, 12-03-2003 16:16:24
I do not have a 3-point. I don't know what all the rage is about 3-point hitches. I personally do not like them. They cause me more trouble than they are worth.
harry junior
12-04-2003 18:10:00
 Re: Re: Re: Pull Behind Brush Hogs in reply to Martin Miller, 12-03-2003 16:48:55
wow did you hear that noise? it was harry ferguson rolling over in his grave..is your other tractor a mule or drafthorse??
RayP(MI)
12-03-2003 17:03:47
Used both - both do good job when properly adjusted. Trailer type is somewhat less manuverable, but if you're thinking ahead, you'll get along fine. Last year, son and I worked on the same field, I had a 3pointer, he had a trailer type. Couldn't tell the difference when we got through.
Stan TN
12-03-2003 18:02:32
 Re: Re: Re: Re: Pull Behind Brush Hogs in reply to RayP(MI), 12-03-2003 17:03:47
Ditto!
Dave_D
12-03-2003 19:02:34
 Re: Re: Re: Re: Re: Pull Behind Brush Hogs in reply to Stan TN, 12-03-2003 18:02:32
Pull behinds are near inpossible to back up with. That being said, I like using my pull behind for field mowing, less weight on the tractor. Pull behinds are usually further behind the tractor, so there is more potential of stuff getting thrown back at you. I have chain guards to keep this to a minimum.
- Dave
Muskrat
12-08-2003 14:02:15
 Re: Re: Re: Re: Re: Re: Pull Behind Brush Hogs in reply to Dave_D, 12-03-2003 19:02:34
I used a belly mounted one a farmall cub. It worked good but it was a pain to put on the tractor.
