JOHN DEERE 327 VS 337 SQUARE HAY BALER
BOB
05-09-2003 14:42:34
I HAVE FOUND A 327 AND 337 BALER FOR SALE THEY BOTH LOOK GOOD. AND BEEN KEPT DRY AND LOOK ABOUT THE SAME WEAR. THE 327 IS PRICED CHEAPER. I HAVE ABOUT 100 ACRES OF GRASS TO BALE WHICH ONE WOULD YOU BUY AND WHY ? THANKS
Lary
05-14-2003 20:12:23
 Re: JOHN DEERE 327 VS 337 SQUARE HAY BALER in reply to BOB, 05-09-2003 14:42:34
Bob; We use a JD 348 with a wide pickup, In good conditions, we can fill an 18 ft wagon in about 15 min. It has 101 plunger strokes.My nephew has a 338, in large windrows he puts out a bale every 4 sec, a good 336 should do almost as good. Lary
hntndaylight
05-11-2003 18:12:08
The 337 would be 90 plunger strokes per minute the 327 something like 78 or 82 (I think, never really studied them that much, other than remembering they are lower). For a hundred acres of hay I wouldn't even consider the smaller baler or smaller pickup. I've got a 336 (90 ps/min also) and about 220 bales an hour is about all I can get it to physically bale. From start of bailing to end of running the bale wagon about 1500 bales per day is about all I can do. That's 8 acres of good timothy for me, would take forever to do a hundred acres, I only do about 80 acres in small squares and it kills me for about 6 weeks. I've been lusting over new balers but can't find one with higher capacity in a small square.
Bones Magoo
05-11-2003 15:00:55
About 15 years ago, Dad and I used to put up 7,000 bales a summer with a 327, and never had a lick of trouble out of it. The 337 may be a more deluxe version, but I sure wouldn't shy away from the '27.
heath
06-03-2004 09:55:45
 Re: Re: JOHN DEERE 327 VS 337 SQUARE HAY BALER in reply to Bones Magoo, 05-11-2003 15:00:55
i work on my cousins farm and he owns a 327 and we havnt had a lick of trouble until this year when a piece of wire was scent through the knoter and it wore the right knoter and we spent 1500 dollars to buy 2 new knoters. Other than that it is a great baler
heath
06-03-2004 10:00:46
 Re: Re: Re: JOHN DEERE 327 VS 337 SQUARE HAY BALER in reply to heath, 06-03-2004 09:55:45
i bale around 5000 bales and i would go with the 327 instead of the 337 because i have run bolth of them and it is much more relyable and is much more easyer on the ground.
Bill B
05-09-2003 21:12:28
I have a JD337, which is just a more deluxe version of the 327. The big difference is in the pick up is 10 inches wider and has 6 rows of teeth verses 4 rows on the 327. A 337 has a cat 4 drive line and a 327 has a cat 3. I looked at both 4 years ago when I bought mine and went with the 337 becuase it was in better shape. Now that I have it I'm very glade that it has the wider pick up. Unless there is a big difference in price I would go with the 337. Bill
Bill B
05-09-2003 21:11:27
