lastcowboy32
One of the tilt rams on the loader was leaking hyd fluid. HPGL4 rated fluid is twenty bucks a gallon, and I was going through about a gallon a week, when the tractor is running a lot. So I got a seal kit. I got the gland off and got the ram out easily. But, when I went to take the end off, It was stubborn... so... my wife and I got on both sides, she had a six foot bar to hold it from turning. I had a 3/4" breaker bar with some pipe on it.
Well... it turned hard for a long time. Then, when we had it almost all the way off... That split fiberglass seal/linear bearing rotated to a spot where I could see... a set screw...
Underneath it.
I loosened the set screw, but it was too late. Damage was done.
Underneath it.
