Ezee flow 88a drop spreader
If you take the lids off you can get a ton in it. The main thing is to make sure you use dry material. Any moisture will cause a bridge and then you got problems(BTDT) . Also, keep the agitators engaged all the time. Good Luck.
(quoted from post at 00:16:44 03/30/21) I was wondering if anyone knows how much bulk ag lime it takes to fill the 88a.
I wouldn't even try it unless the lime is bone dry.
