lastcowboy32
I know. Odd time of year to be thinking about it. But here's why.
I have a lot of time to think, as I'm putting manure on our sweet corn patch this fall. The manure is the first step to turning things around from last season...which was a complete bust. Between lack of nutrients and a record wet summer/fall... no bueno.
But anyway, one of the problems this year is that I didn't get the corn cultivated soon enough. That is already solved for next year, as I bought an old set of John Deere cultivators and repurposed them them to hook onto my Ford 3000's three point hitch. They are lubricated and stored for the winter. Ready to go at a moment's notice next year.
The second problem was nitrogen... hence... lots and lots of manure going on this fall to be tilled in next spring.
The third problem was germination. I borrowed a White 5400 Plant-air Planter from a neighbor, who uses it for deer food plots.
There are a few problems with this. The hoppers are setup to be loaded with 50lb bags of seed corn for planting acres and acres of corn. When you put a few pounds of sweet corn seed in, you have to cover it with a rag and a weight to make sure that the planting rig stays pressurized. Even with that, only two rows of the four planted very well last year. I have a short time window to borrow this planter and not much time to troubleshoot it. (As an aside, its owner also had the same problem). I don't mind fixing something for a friend who lets me borrow something, and maybe I can figure this out over the winter... since I store the planter in our hayloft for him.
But here is the question:
Can I get double duty out of our cultivator? Would I be able to put sweeps on it that are designed to make a small furrow for dropping seed into?
If I could, I wouldn't mind spending maybe 100 bucks on one of those seed meter setups with a wheel that you walk behind to drop seeds.
Yes... I know... labor intensive. But at least I would SEE the seed dropping every six inches (or whatever) and not have to wait a week or two before realizing that the planter only planted less than half of the plot... by which time I'm screwed.
It seems that using the cultivator for making the planting rows would set the rows up perfectly for the same cultivator to then go between them.
It also seems that, if I paid more attention to micro-managing the plot with nutrients, getting the proper seeding and cultivating, I bet that I would be able to get the same amount of sweet corn on about a third of the ground that I tried to do this year.
