Farmall A-22 sickle mower belt length
Kirby337
I am putting back together a a-22 farmall
sickle mower. Does anyone know the belt
size or a part number for the correct
part. Where is the best place to purchase
one? Thanks for your help.
Have you checked with the local FIAT dealer, likely it's still available, get a price and a part number, then check with JayDee enterprises.
https://www.jdv-belts.com/
If you have/can get the OEM part number,jayDee Enterprises can cross and supply the belt. Often at half the price of OEM.Good people.
I don't know that much about them but is not on the A tractor the PTO offset like a cub to left side? The C the PTO is centered to tractor so I would think they are different. This is assuming they are both mounted mowers with the belt pully to drive mower mounted on the PTO shaft. I am sure one is for the single row offset tractor and the other is a standard tyoe 2 row cultivating tractor. So if mowers interchange between tractors I do not know.
Looks like nobody is going to tell me if I am correct on the location of the A PTO shaft.
