Planter Monitor
Rich.Fl
I have an old JD Flex 72 planter I use for planting peanuts. I would like to add a basic seed monitor.
I am not very knowledgeable but have looked around a bit.
Any Suggestions?
Thanks!
Rich
Here is a thread from 2009 on another ag forum that talks about it some.
It appears your problem will be fitting a seed drop monitor in each seed tube. Half say you can?t, the other half say you can make it work.
https://talk.newagtalk.com/forums/thread-view.asp?tid=95019&DisplayType=nested&setCookie=1
As the 71 unit planters are still made today by Yetter, you might need to know how old your units are, they have been in production for over a
half a century, started with steel cans, now fiberglass, I bet the seed tube has changed some over the years as well.
Paul
71 monitor discussion
