I have a '66 3000. I've found a loader that's currently on a 4600SU that I'm going to look at tomorrow. I found a loader on eBay that looks just like it that says it's a 19-557. I can't find anything searching for a 19-557. The owner just bought the tractor with the loader on it and doesn't need the loader, so he doesn't know a lot about it. He said that it was originally set up with a crank driven pump but it's gone and it works off the on-board hydraulics. At least the left arm has been repaired, you can see it in the pic. I can't tell if the lift cylinders are 1-way or 2-way.
From what I find this should mount right up on my 3000. Do you think it would function ok hooked into the hydraulics on my 3000 or am I going to have to find a pump? Any info you can give me would help if anyone knows anything about it. I'll know more after I look at it.
