I do not have much to go on but maybe one of you will know who made it. The main part of it is red. Arms the 4 wheels/tires are on are black. 3 of 4 tires are tube type and the 3rd is a hard rubber tire which is likely to have been replaced. Pulley cover is one piece and white in color. Has 3 blade spindles 5 idler pulleys. 2 of the idler pulleys are also used to tighten the belt. One has a slide that is tighten up with a threaded rod and the other tensioner is sprung is it can tighten the belt but yet let the belt have some play. It has the newer triangle type PTO shaft. I has NO markings or tags of any sort any place on it. Well it does have one tag on it but the guy I got it from said he put it on so that one does not count. LOL. So with that does any body have an educated guess as to the brand?? I know not much to go on and I do not have any pictures.
Thanks
Thanks
