19 spline 1 inch universal joint yokes
wally b
I have a wadco grader. the blade controls run off a male stub spline shaft that is 19 spline and 1 inch od. I am looking for a universal joint yoke that will fit this
19 spline with spline diamenter 1 inch and shaft diameter not including splines somewhere in the 885 to 915 thousands of an inch.
Anyone know a source for these? Old grader parts?
What part of it is bad?? The splines or the u-joint area? As for parts you might try this number 40-439-5512
The splined power output is intact. The shafts and universals from the 1 inch, 19 spine power output shaft to the leaning wheel transmission are missing so I need a universal with a yoke to fit this power output spline.
What company should I use to search for that part number?
Thanks
740-439-5512 is the phone number of an equipment salvage place that I have found parts for machines I have worked on in the past. Stupid keyboard missed the 7 in my first post.
