So I have the 2 outer spindles rebuilt with new bearings and seals and installed. Went to remove the center spindle and the pulley where you take the bolt out and put them in to pop the pulley free for the clamp holder I broke one of the bolts to pop it free. Tried a different bolt and it too broke but it broke flush with the piece it goes in. It is a 1/4 inch bolt so not much room to drill it out. Not sure how I am going to go about taking it apart. I have it soaking with ATF right now and may try a left hand bit if I have one small enough to try to drill the broken bolt out. I may even try a couple of chisels on each side to see if I can pop the pulley free form the center clamp part of it. Or maybe some heat. Not much other I can think of trying so anybody have any other ideas??
Thanks
Thanks
