Hi, just acquired an old mf 110 manure spreader, in pretty good shape, except for a couple of floor chain crossbars that has been
reinforced or bent. Any info on that model of spreader would be greatly appreciated...
first question. should I lube the the chain drive gear with grease or clean it and leave it alone as i suppose dirt will stick to the
grease and so on?
second question. the bottom floor planks are all gone eccept for two ends, I can tell the lenght but I can't tell the width and thickess
the planks needs to be. I'd like to put it back as close as possible to original as the rest of the machine is pretty much as good as new
except for a dent here and there... Thank you for any inputs Guys and have a great day!
grease and so on?
