When adding oil into my cutter bar I noticed afterwards once I raised the bar up in route to the hay field, that I had a small leak coming from under one of the cutter
holders. But it only seems to leak when the bar is raised. Do you all think its a good idea to finish this hay season and just keep the bar full and repair the leak
later? Or is this a easy fix to replace the seal and just repair it now?
