Does anybody have any idea where I can find the short stub shaft that goes in the back of a loader PTO pump so I can run an implement without removing the pump. I have purchased the long shaft from Double H products and other companies. They are now made in India and they are not hardened. They twist and bend like butter. I have gone through 4 shafts that have twisted yet I cant break a 5/16 soft shear bolt!!! Apparently these stub shafts had a bolt in the center you tightened and it locked the shaft into the pump. Any info on a long hardened extension shaft or this farmhand short extension shaft would be appreciated. If anyone has one they would like to part with I will be happy to compensate you well for it. Thanks in advance. Nick
