Farmhand loader pump shaft
nick831
Does anybody have any idea where I can find the short stub shaft that goes in the back of a loader PTO pump so I can run an implement without removing the pump. I have purchased the long shaft from Double H products and other companies. They are now made in India and they are not hardened. They twist and bend like butter. I have gone through 4 shafts that have twisted yet I cant break a 5/16 soft shear bolt!!! Apparently these stub shafts had a bolt in the center you tightened and it locked the shaft into the pump. Any info on a long hardened extension shaft or this farmhand short extension shaft would be appreciated. If anyone has one they would like to part with I will be happy to compensate you well for it. Thanks in advance. Nick
There use to be a place called Hub City Iron Store,they were out of Aberdeen South Dakota, they made all that kind of stuff,you would see their display's at farm supply stores, do u have a good machine shop close bye to help u out? It's a open shaft yellow pump type u have right,somebody must have them i have seen a lot of cattle feeder's use the feeder wagon with the loader tractor !
I would find a way to hook the pump to the belt pulley drive,or run it from the front crankshaft pulley.Then you would have 'live'/constant hydraulics.I would not want to run a baler with an extention.IMHO,that is an accident,bid repair bill waiting to happen. How do you keep the right distance from the drawbar to the PTO? Longer drawbar?
I can call hub city. They no longer show one in their catalauges. The only thing I am running with this is a post hole digger, 5 foot mower and an 8 foot loftness snow blower, nothing pulling much horsepower.
