Seal Interchange for Alamo/Rhino Bushhog - Need Help
RTR
I need a couple of seals for the gearbox of my Alamo AG-72 bushhog cutter, and trying to cross reference the Alamo part number it only comes up with the oil seal under their number (which I'd have to order). I'm wanting to cross it to a generic seal part number so I can pick one up by tomorrow and get this thing back together. My cutter is an 1994 Alamo brand, but I'm pretty sure the Rhino bush hogs are the same or very close. The Alamo part numbers for the seals (from the factory parts diagram) are as follows:
* Upper gear box seal # 00758653
* Lower gear box seal # 00758674
No markings on the seals?
I dropped the first zeros off and just googled "758653 seal"
Looks like it crosses with SKF17271 1-3/4" I.D. x 2-3/8" O.D.
758674 just comes up as Rhino M50x70x10 double lip oil seal
I just take the old seal or even just the inside and outside measurements to my local bearing store and they give me the new one.
I thought it would be easier to cross the part numbers since the numbers on the actual seals would be the same as these. Thank you for the suggestions of dropping the zeros off the numbers. Looks like I can
source a seal locally since it is something that isn't Alamo specific.
