Ford 712 Loader
vikingsfreak
New User
I am having one heck of a time finding some parts for my Ford 712 Loader and was directed here to look for help. I attached a screenshot from the parts book.
The part number are coming back as:
108450 Shaft assembly (17 in photo) or individually what I need is
108448 Yoke, tractor side(21 in photo), and
108416 Hub assembly(27 in photo).
This is being used on a Ford 1841 tractor. I live in Northest PA if I have to travel a bit, but if I can order online would be ideal.
Thanks for any help, my searches are turning up nothing.
I dont think you have to use one like the original. I have a 730 loader but it uses a 13 spline shaft with 2 of those rubber cushioned steel flex joints and the drive that mounts to the belt pulley. You can find tham at CNH partstore under loaders but you have to click on the 712 model i think to see the other models of loaders. Then you can search out the pump and drive section. Mine has an Eaton pump like in your picture. My tractor is a 4030, I think. I think they sell the drives on YT.
Thank you for your response, I didn't get a notification.
I looked through everything that they have and all the parts listed are shown as not available.
As far as you know, would I hurt anything to weld the splined yoke to the flex flange? It may be my only choice and that is the only place where I have a problem.
This tractor does not get use a lot, but is very handy to have when I need it.
