TractorLinks.com
John Deere, model 44, rope pull plow
Dwight Tuttle
06-12-2018 22:05:19
I'm trying to remove the left wheel [clutch side] from the axle.
I removed the cap, I removed the pin from the axle. The wheel will
slide a little bit on the axle, but will not come past the edge of
the axle. It feels like something is holding the wheel on the axle.
The three bolts are loose. Also, if anyone has a manual, that they would be willing to sell, please let me know.
Thanks, Dwight
JDBRIDER
06-13-2018 19:13:57
 Re: John Deere, model 44, rope pull plow in reply to Dwight Tuttle, 06-12-2018 22:05:19
Been a while since I had mine apart but I think that you have to remove the nuts from the bolts. Then the wheel will come off. Then the piece behind needs to be turned maybe 1/4 turn to remove it.
david from kansas
06-13-2018 05:23:48
Tyler the plow guy has a video on youtube. Type in "John Deere plow enclosed clutch".
ET
06-13-2018 05:07:42
The wheel is a tapper press fit onto the hub. You need to rig a puller to get the wheel off the hub.
Dwight Tuttle
06-13-2018 23:57:06
 Re: John Deere, model 44, rope pull plow in reply to ET, 06-13-2018 05:07:42
I can use a puller, to get the wheel off. Then what do I need to put the wheel, back on the axle?
Leroy
06-14-2018 05:29:11
 Re: John Deere, model 44, rope pull plow in reply to Dwight Tuttle, 06-13-2018 23:57:06
Just clean and enough anti seize to cover to help in dissembly again years later and assemble and bolts will tighten it up
